New trailering tie down system
  • New trailering tie down system
    Sorry thats the only way I knew how to describe it. Was at the bike shop today having my tires flipped around, and saw this in a magazine. the ad said "argo now available" caught my interest until I saw the price. $699! But if anything for you fab guys, you maybe able to make your own. seems like a pretty simple design. I may try to think up my own set, cause my straps tend to come loose on the back from the wonderful illinois roads we have
    SuperClamp.Net: Manufacturers of the Industries Leading Snowmobile and ATV/UTV/SPYDER tie-downs.
    I think this style is the best idea
    Over-the-Wheel Tie Down Bonnet
      I was really thinking about buying some of those, but now that I have my bumper I can just strap to the d-rings or do what I used to do and go around the axles
        Theres no way I would spend $699 on a system to strap down my atv, your link does the same thing and %90 cheaper!
          It looks like it works good but it new. Hows it going to work when it gets some mud in it?
            hi
            Try this all of the above versions
            track system
            Lassoo [loop] single point tie down
            Wheel bonnet types that pull tire to side of trailer
            Wheel bonnet types that pull front and rear of tire
            CTS Cargo's Canadian-made tie-down straps, cargo nets, rigging hardware & flatbed gear. Trusted cargo control manufacturer since 1999.
            Go to wheel tie down section
            tomo
              Yep, the webbing wheel tie downs work well, it's what I use. ................But seeing as we make them for a living it's not surprising I use them
                I like this for the rear, other companies make it flat to mount to a trailer, and then use the winch for the front
                Lock-it Rite ATV System
                2003 Argo Conquest
                Wasilla, Alaska
                  If I didnt have a front push bar and rear rack to tie to (Both a MUST imho), I just hook to the rear hitch reciever and the front Winch Bracket. Running Tracks leaves you with limited options.
                    b
                      B
                        I have seen the super chicks at a local trailer dealer. They look very good, but the price can be a real belly drop. The tie-down bonnets look good, but might not work so well with tracks.
