Needing some ideas about gun and bow mounts. Where did you put them? I have an Argo Response and cant decide where to put my two-gun mount so that my bow or rifle is inside the machine and protected. Some pics of where you mounted yours would be greatly appreciated.
Gun and Bow mounts on AATV's
I had the same problem last fall before my moose hunt for my Frontier. I couldn't find any brackets that would realy work with the gunboot. Ended up making my own. 1/4" plywood base using the factory back rest bolt holes. A "U" bolt at the barrel end of the case. Some aluminum tubing for spacers (so the cap is not contacting the plywood and can be easily removed)and bolts in the gunboot factory holes. It's solid and worked well.
I just drilled holes thought the pe by the hood and used large washers and lock washers. You can see my gun mounts in this picture. It is the only picture I have right now where you can see them.Attached Files
Bought the Kolpin® ATV Gun Grips II that Bass Pro sells and mounted them to the top seat rail bracket on the rear bench seat. Would also work on the drivers seat.
Things don't move. Sorry no pics on this right now.
