Does Buffalo Bearing Or someone else sell the correct inner and outer bearing flanges for Attex Chief?
Attex Bearing Flange
i think the outside ones are discontinued, so no. The inside ones are available from Buffalo Bearing though. Tell them you need the two piece, two hole, 52mm OD bearing flanges for 6 wheelers and they should know the ones you need. I believe Fafnir used to make the outside ones.....I think I have a used set or two I could sell you."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
