Does anybody know the maximum load for towing is?
Towing capacity of Conquest
Looked up my electronic owners manual and it is not listed. I would assume that it is the same as the payload max. 1000 lbs. I know I have pulled other 8x8's out of mud holes without any difficulties, just used low gear.Originally posted by Paul219 View PostDoes anybody know the maximum load for towing is?
Just done a quick google search and it states the towing capacity for a conquest is 1600lbs.
Argo Conquest 8x8
Here is some other towing capacities for other models...
Vehicles | Ottawa ArgoEven if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
Hey Doc, I thought that you kinda reached for the carry capacity once with a load of plywood. No?Originally posted by Rock Doctor View PostMax Towing capacity for my Conquests is as much as they can pull without spinning out. Usually limited by ground conditions, soft, muddy, Muskeg, ect.
Hahaha, I think that was 17 sheets of 1/2" and 3/4" OSB Plywood across the back of the machine, I think thats close to 1,200lbs. Then the gear under the wood, plus a couple 200+ lb guys. It was probably about a Ton on the Conquest, that was the second load that day, and the only time I've ever broke an Axle. Was winter and in deep snow, no trailers involved :-).Originally posted by philipatmaxfour View Post
Originally posted by Rock Doctor View PostHahaha, I think that was 17 sheets of 1/2" and 3/4" OSB Plywood across the back of the machine, I think thats close to 1,200lbs. Then the gear under the wood, plus a couple 200+ lb guys. It was probably about a Ton on the Conquest, that was the second load that day, and the only time I've ever broke an Axle. Was winter and in deep snow, no trailers involved :-).
So you busted n axle and just kept going! Wow what a beast. I can tell you right now I baby my machine compared to how you drive yours. You are a true insperation Rock Doc. Lol
No, not at all. My machine ended up sitting right there in the middle if the trail for about 2 months, untill spring when I could get to it with my quad and change out the axle. I drove my buddies machine back out.Originally posted by Twizted1 View PostSo you busted n axle and just kept going! Wow what a beast. I can tell you right now I baby my machine compared to how you drive yours. You are a true insperation Rock Doc. Lol
This is from the trip in to fix it
RDLast edited by Rock Doctor; 10-27-2014, 12:13 AM.
Ya, it's not like that here, mostly.Originally posted by Nubs View PostMy unit wouldn't last a day left on the trail. Nice videos
As you may have noted, I went back to fix the Argo by myself, that was in the spring. I ended up leaving my quad right there beside where the Argo was untill about the middle of the next winter. No issues at all.
