Anybody built a sheet metal cab and what are positives and negatives of it. How hard is it to work with? I'm starting a treated plywood cab and think the weight might be too much. The benefit of wood is that I can put windows in alot easier then with sheet metal. Ideas, thoughts or suggestions. One thing I forgot to mention is I take the wheeler thru the woods ALOT. It takes a beating going over and thru the woods to grandmothers house.
Sheet Metal Cab?
I built a hardtop for a Jeep M38a1 a few years back. I started out with marine ply and realized the weight made the machine top heavy, so switched to luan plywood and put several coats of clear on it. It worked great for several years. Then trail abuse got the best of it. So I covered the roof with thin metal and got another three years out of it. I used plexiglass for the windows.
The entire top weighed in at around a 100 pounds.
If I were going to do it again, I'd use luan plywood, with the stitch and glue technique, and cover it with fiberglass. I'd use plexiglass again, but keep in mind it yellows quickly out in the sun.
Here's an explanation:
Stitch-and-glue boat building, along with the development of epoxy and modern mahogany marine plywood, has revolutionized and revitalized wooden boat building. It also works for jeep tops, sheds, etc., Where horizontal and vertical panels come together, bailing wire secures the panels together, then epoxy and glass resin covers it. It makes for tight seems, and lightweight construction.
I have considered that as an option. Have you made one? If you have, how much does the polycarbonate cost? I would think that for larger sheets it would be real pricey. I would love to find some plastic that you could heat and it would conform to the roll bar over the machine. You could then cut out the windows and doors."I'm NOT stuck, I'm just temporarily stopped"
wheeler, i have a 3 wheel trike that i made a complete bubble enclosure for so i could ride it in the winter. i used 3/16 thick polycarbonate sheets. they sell for around $ 35 for a 2x4 foot sheet. i made a frame work first, them made templates out of cardboard. once i had the pieces traced and cut onto
the poly sheets, i cut them out with a jigsaw and fine metal blade. any bends needed i softened the poly with a heat gun and it bent easily. all pieces i attached to the framework with small round head bolts and cap nuts. i also bought a special adhesive for poly that bonds quickly and is very strong. it's very tough and all clear. looks alot like a canopy on a jet fighter. anyway, hope it gives you some ideas. you can by sheets up to 4x8 foot. check around for suppliers and prices. johnboy va.
Just google " thermoplastic" and loads come up. Then google the spec for temperature required to form it. H.I.P.S. is a very cheap plastic, relatively strong (but can shatter when thin sheets get very cold). It's what a lot of the bodies for radio controlled models are formed from.Originally posted by wheeler View PostI have considered that as an option. Have you made one? If you have, how much does the polycarbonate cost? I would think that for larger sheets it would be real pricey. I would love to find some plastic that you could heat and it would conform to the roll bar over the machine. You could then cut out the windows and doors.
Johnboy, do you have any pics? I can visualize what you did, but the bends and all are a little tough. It is always good to have a pic to spur on the old idea factory.Originally posted by john swenson View Postwheeler, i have a 3 wheel trike that i made a complete bubble enclosure for so i could ride it in the winter. i used 3/16 thick polycarbonate sheets. they sell for around $ 35 for a 2x4 foot sheet. i made a frame work first, them made templates out of cardboard. once i had the pieces traced and cut onto
Mike
hey guy's , if you already have some uprite front poles and a back rollbar, to finish out a frame just connect them front to back with some 1'' litewall square tubing. basically your looking to make a square frame like a box. that way there is really no need for bend the poly. top, sides, front and back will all be flat sheets.once they are attached to the frame, just attach the poly with small nuts and bolts or rivets,etc. all the corners can be edged with liteweight aluminum angle. when you cut the templates, have them follow the contour of the body. you can even put rubber edgeing on the edges of the poly. you don't want the enclosure airtight anyway. before installing the last side, cut out a door from top of the sheet to the bottom however wide you need to get in. hinge it at the front frame tube and install a latch . the nice thing about a all clear enclosure is ,on a cold sunny day it's warm inside like a greenhouse. i've been in my trike on a sunny 30 degree day in just a t shirt. anyway these are some basic ideas to think about. it's really like what you would do with wood pretty much. let me know of other questions johnboy va.
Hey guys, I am in the process of fabricating a compleat enclosure for my MaxIV with nothing more then some pickup bed liners that were given to me. All bed liners are made of abs plastic and can be formed very easy.because of the heavy ribbing that they have,I was told you can install polycarbonite or acrylic windows wedged in a rubber window seal like they use on many outdoor construction equipment. Cutting the abs is fairly easy with a proper blade and to form the abs around the roll bars are also easy using a heat gun or a heat tape that you can buy on the Internet that will help in bending the abs or your polycarbonate or acrylic windows for that matter.I will be posting photos of the work in progress as soon as I can figure out this new I phone six and how to post on the site. Stay tuned and if you have any questions I can answer for you, please feel free to ask. Talk to you all later and hopefully with photos take care and God Bless.
Jerry.
I use part of a truck bed liner for a hard top on my maxll. I believe they are hdpe. I have blaze orange camo doors that my sister inlaw made for me. They snap in front and back, Velcro around the cab bars at the top. Vinyl windows.I had her put in zippers from an old ground blind so that I don't have to unsnap the doors. The door cloth has a black rubber backing so it is water proof. The cloth is called true timber. Will try to post some pics soon. My front and back windows are plexiglass.
