I just purchased a 8x8 Conquest this fall. It has tracks with custom rubber extensions. So, its 82 inches wide. I don't want to take the tracks on/off to haul, we are trying to use it for winter cabin access her in Colorado.
Most utility trailers are too narrow between the wheel wells. I am on a major budget for this trailer. I looked on craigslist and picked up an 8x10 snowmobile trailer for $40 that someone was going to scrap.
On of the main crossmembers had rusted through on both ends, so I cut it out and replaced it with a new 2x3 tube steel beam. Reattached the suspension. Refurbished the deck a bit and replaced the wood parts of the deck with new pressure treated plywood.
The 2nd stage of this buiild will be to build a lightweight enclosed top for the trailer. So, I can store the Argo in it when not in use, since I have no garage space. Also, it would be nice to show up at the cabin with a clean Argo rather than one covered in snow and ice from my drive up to Fairplay. Anybody on this forum attempted a trailer build like this?
Only thing I am leery about is the leaf springs are a "slipper" type, c-hook or open-eye type on the back. They seem a little precarious like they could come unseated from the shackles/hangers. Hard to explain, will post pics. Might need to weld some additional plates underneath to make sure they are secure. Don't want my 1000lb argo bouncing around on top going 70 down the freeway and have the leaf spring come unseated.
I took it for a test run, the trailer was squirley above 55mpg. Is this common for a sled trailer unloaded? I put about 500lbs on the trailer and repeated the test drive, the problem was gone. Can anybody with a sled trailer comment?
If the trailer is stable and can handle the weight, I move on to phase 2 - adding an enclosed top.
Thanks!
Thanks!
But, maybe you are pulling your trailer with a diesel truck and not a jeep with a minivan engine!
