How do I align new sprockets before I put new chain on? (replacing tensioners)...I know they need to true, but how close do I need to be?
New chain/sprocket alignment
If I remember right, the tensioner sprockets are aligned via a series of washers. There ought to be several on each side of the tensioner sprocket to center it. The axle chain tensioners are like this, So I figure the primary chain tensioners should be, too.Stand for the Flag. Kneel for the Cross.
I will say that if Mark says its a good product and he uses it then its worth it. He will not steer you wrong. When the time comes to replace these sprockets I will buy them.Originally posted by snackmaster View PostAnyone use Agri Supply 17t, 1/2in bore? another member said they're better and only $10...Max wants $34 each.Stand for the Flag. Kneel for the Cross.
