So I got a couple of LEDs for Christmas, I had been wanting to do a lighting upgrade so that worked out great. I went for a Christmas Eve ride and while entering a creek after dark, got the back of the buggy hung up on a submerged stump which reminded me of a couple of things. First, when I built the bumper/winch mount I had no idea where the machine's waterline would be only to learn it was higher than I thought and the warn gets a frequent dunking. Second I need better lights. And third when winching, if the anchor point is to the side the line will stack up and make a mess which is only compounded if one must then reverse the winch. Time to relocate the winch. For some time I have been planning to build some custom bumpers for the Toyota 4 Runner I gave one of my sons. I long ago built a small brake set up for my shop press but it is too small for that project and also for the plate for the new winch mount/light bar. So I took some of my Christmas cash and went to Magnolia Steel. My question is do I now build a rigid mount, a receiver that would set down on the hitch ball, or a swivel which would allow the winch to self align?
What's the trouble mentioned in the title? Well since the small brake is only good for small projects, I decided to build the bigger one that I've been wanting to build. I spent 10 hours grinding the edge on the 3/4" bar. It is 4' 1/2" between uprights, that means I can now bend up to a full 4' piece of 1/8' plate. The last pic is the body mount plate I bent with it for the new winch mount/tree knocker/light bar. The new brake will need a 30 ton jack to go full capacity and a little top bracing to get there but I am more than happy with the outcome.
Sorry for the delay on the pics, my phone freaked completely out and wouldn't even think of uploading them. Had to import them into the pc to get them on. So what do you guys think, rigid, receiver or swivel?
, having a rigid mount makes it easier to get the cable to lay up against the previous wrap, because the swivel allows the winch to move as I try to guide the cable into position. The swivel did help when coming out of a swift water crossing because it allowed me to drive out of the water while being anchored to the side of the trail. I am thinking of adding another led pod to the top of the winch so it is always aimed at the end of the cable. Other things under consideration are drilling a couple of holes through the base to pin it in a fixed position, or unpin for swivel, attach a push/pull cable and camera mount for panning while running video, so I guess this could have its advantages. All in all on the 0 to 10 "absolutely must have" upgrade scale, so far this one gets about a 3.4.
Not one of my best ideas, but not the absolute worst. I am liking the pod/camera mount thing though.
