Has anyone ever swapped in some snowmobile calipers and master cylinders in an older mechanical brake machine? I've been looking at friends snowmobiles and seems like I could rig it up, just wondering if anyone has tried it or if there are other cheap options out there
Hydraulic brake upgrade?
I am sure I read about someone in this forum adding hydraulic brakes. I don't know if they used the ones for snowmobiles. I think anything you decided to use would require modifications or brackets or whatever. If you do the mod, please post pics along with your step-by-step progress.
It is possible to do a conversion, you may be best to do a conversion similar to the early KB models. A big problem will be figuring how to mount the master cylinder and the caliper to a system that is so much earlier in design. There are no mounting points for these either frame wise or transmission wise.
Properly functioning manual brake systems are actually quite nice to drive.sigpic
