What's in your toolbox?
  • What's in your toolbox?
    I'm putting together a tool box for the max here is what im planning on bringing: 130 link 530 o-ring chain, two spare master links, tools to change chains, roll of electrical tape, Two crescent wrenches for adjusting tensioners, paper towels, tire plugs\tools
    I have a common spare chain made up with with several master links in it, I can use it full length for my longest chain or remove the section I need.
    Bicycle pump
    tire plugs
    various screw drivers & wrencehs, pliers, wire cutters etc
    1/2" ratchet, extension and socket to remove tires
    a pry bar
    a paddle
    pruning saw
    zip ties
    bailing wire
    duck tape
    2 new spark plugs
    latex gloves
    valve stem and cores
    spare drive belt
    spare alternator belt
    ratchet strap
    50' winch line extension
    winch anchor
    LOL, I think that's about it I do not pack absolutley everything unless I'm planning on travelling somewhere where help may be out of reach but I do keep 90% of that gear packed under the back seat. If it's just a short trip I leave the spare parts, tire pump and winch anchor behind but always have my tools.
      thats a very good list. I also forgot to add that I am putting spare drain plugs and zip ties in.
        don't forget a small hand mirror and flashlight, it really helps seeing in those tight places
          That's a good idea, flashlights are Always good to have
            Here's a few things I carry in the winter. Long handled shovel along side the seat, ice anchor to winch from, tire pump, ice auger, and a storage box in the engine bay with most of the stuff already mentioned with the addition of fuses, fuel pump, leatherman tool and fishing line to tie the throttle half open when the throttle cable breaks and I'm two miles from shore with the fish house in tow lol.
              Although lots of these tools are generic to us all I always enjoy reading about the things that people in different parts of the country carry.
                I tell you what I wish I had after last weekend: a small socket set and wrench set! taking a carb apart while out in the swamp was terrible!
                  This was a list I wrote up a long time ago, it is by no means "All Inclusive", and over time it had been slightly modified. Keep in mind that I often ride alone, and could be up to 15 or 20 miles from the nearest road.
                  Some of the things I carry...........
                  You might want to pull up a chair
                  Pretty much every tool needed to work on the machine. (Any time I work on the machine, I try to use only the tools I carry with me). They take a suprisingly small amout of room ( I use a "Dewalt" 18v Cordless drill box, with deviders removed). Fits in the hollow in the front floorboards PERFECTLY.
                  Spare outer Bearing housing W/ seals, Spare nuts
                  Outer bearing (Idler shaft brng)
                  Most springs and little conecting rods for the carb/throttle linkages
                  Little bushing under the throttle linkage (Droped one of those before)
                  Mechanics magnet and mirror
                  Pushrod
                  Master links
                  A bit of each kind of chain
                  Chain Breaker
                  Belt
                  Dry Graphite lube
                  WD40
                  Isopropyl gasline antifreeze
                  Spark Plugs + wrench
                  Tie down straps
                  Spare tire/rim
                  Track pin + Collar
                  Snatch Block
                  Heavy rope (winch line extension)
                  Spare hitch pin
                  Spare Trailer hitch spring/Tongue/Jam Washer
                  Chainsaw/gas/oil/file
                  Axe
                  Throttle cable
                  Air Compressor
                  Wire connectors/plyers
                  Headlight (flashlight)
                  Engine oil
                  Grease Gun
                  Gloves
                  Brake pads/Soft Kit/brake fluid
                  Fuel filter
                  Spare fuel line
                  Spare valve caps/Valve stems
                  can of "tire inflator goop"
                  Feeler guage
                  Misc. Bolts/washers/splitpins,ect (just a few)
                  Either
                  Rags/towl
                  Hand cleaner
                  Lighter/Benzo Torch
                  Firestarter
                  Fishing Rod/Lures (colapsable kit)
                  Compass
                  GPS
                  Batteries
                  Spare Sprocket setscrews
                  Power inverter (12v DC to 120v AC)
                  Spare body Plugs
                  Fuses
                  Bearing kit for my trailer
                  Tire plug kit
                  Spare cloths/footwear
                  Rain gear
                  Food/water
                  First aid Kit
                  Pack of Cigars
                  Ear plugs
                  Rifle/Ammo
                  BUG SPRAY at least 2 cans, you don't EVER want to run out
                  Note Pad and pencil (to leave a note if I have to walk....Got **** about that once and it wasn't even me that did it)
                  Small Tarp/String
                  No Bilge pump, but I should have one
                  I know there is some more stuff in there, but can't think of it right now.
                  I carry alot of stuff (alot of it is in a kit, that I can put in/take out easily), but I access some pretty romote places, cell coverage is poor at best, and I am often alone.
                  As a general rule of thumb "If you have it with you, you won't need it"
                  Short list of tools..........
                  I'm at work, so I'm going on memory here.......
                  Hammer (with handle cut short)
                  Combo Wrenches, 15/16, 3/4"(2), 13/16, 9/16, 1/2(2), 7/16, 10mm, 12mm
                  8" Adjustable
                  Modified Needlenose Vice Grips
                  Flat Screw drivers (3- Stubby, med, large)
                  Philips Screwdriver (2)
                  Red Handle Robbie Screwdriver (#2)
                  2 sets Allen Wrenches (folding set and loose set{swivel head}, plus a couple spare 5/32" and 1/8")
                  Plyers
                  Pressure guage
                  Torch Tip Cleaner
                  1/4" Drive Ratchet
                  -1/4", 10mm and 12mm sockets
                  -2 extensions and a 3/8" adapter
                  3/8" dr Ratchet
                  -1/2", 9/16", 16mm, and 9/16 med deep sockets
                  -Extension
                  1/2" dr Ratchet
                  -Extension and 3/4, 15/16 sockets
                  track pin punch
                  Test Light
                  Side Cutters
                  Zip Ties
                  Electrical Tape
                  Just winging it, I'm sure that I have missed a few
                  All my tools are in a small box that fits into the floor pan well, and all the parts,cleaners, ect fit in a smallish Rubber Made Tub.
                  By no means do I feel you need all this stuff, and in fact, I use most of my stuff trying to help others that I meet to get going again.
                  Do you think I'm CRAZY yet
                  IF YOU HAVE IT WITH YOU, YOU PROBABLY WON"T NEED IT
                    I've got to admit, you're covered for everything but war. Oh wait, I see a rifle and ammo on the list. You now have it ALL covered.
