All,
I purchase a tow behind wagon / trailer for my Argo that was custom built. It needs help in the axle & bearing department, but I have no idea what body / machine this originally was. I am looking for this info so I can buy the correct parts. I am looking to replace all axles, bearings, retainers, etc.
As you can see in one of the pics, one axle had a poorly done weld job, which damaged the bearings because the axle is out of round. Axles are 1.25" solid. Bearings are stamped: 62MSTRC2 & RA103NPPB5. Flange is stamped: Flangette & FAFNIR & 62MSC2. Body is black fiberglass and the frame shows it originally had 8 wheels. Hubs are 5 x 4.5 and are welded to the axles (axles do not taper and are not splined).
Any help would be greatly appreciated!
Thanks.....AkBillyBow
