ran across another big wheel '' russian sherpa '' type machine. look under atv shatun. this one has a steering wheel and articulates. sorry, i don't know how to directly post it. j.b.
atv shatun
I've seen this before but what I REALLY want to know about are these:
There are TONS of videos of these on you tube and I can't figure out what they are called. On Special Offroad Vehicles
There is an image and it says "home made Russian" but it can possibly be, as there are at least 20 examples all with the exact same layout, tires, etc. Maybe they are kits? But regardless I WANT one, it's like a Coot that floats via tire buoyancy. Shatun articulates via steering, but these articulate in both axis like the coot. The shatun is still essentially suspensionless and static like the sherpa. Also I think I could afford one of these mystery Russian ATVs
Originally posted by allwheeldrive View PostI've seen this before but what I REALLY want to know about are these:
Its called a Demon 400 or a Демон - 400.
found one for sale here
Подать объявление. Частные объявления и предложения организаций.
Used google translate and these go for 300,000 rubles or about 5200 USD
this is the translated verson
В продаже квадроцикл во Владивостоке! Цены на новые и б/у мотовездеходы ATV.
Amphibian Amphibian Demon - 400. Excellent means for movement through forests, swamps, snow, and water. The ATV is universal. He climbs into the car body of the Oise. In the body can carry 4 "good" people, or 6 "ordinary". Below are some of the characteristics:
Frame type - articulated ("breaking"), on the basis of the rotary fist Uaz + SHRUS "Birfild."
Engine - Lifan 190F, 420 cu. See 15 liters. With., Four-stroke, forced air cooling.
Transmission - VAZ-2106, four-speed.
Bridges - VAZ-2106, the gear ratio is 3, 9.
Tires - stripped IDP-284, chamber, the actual size is 1200 * 500-21 ".
Disks - closed, with a badlock.
The load capacity on land / water is 300/200 kg. The equipped weight of the cross-country vehicle is 630 kg.
The maximum speed is 36 km / h.
The price is from 300 000 rubles, depending on the equipment. For all questions, please call.
thanks castro, that is a really cool machine ! and it looks to go pretty much anywhere. lot's of ground clearance. if a guy could import those and the tracked ''tinger atv '' from russia with some reliable product support of parts,etc. , between the two there would probably be a fair market for sales........ each one is alittle different for use. johnboy va.
You'd either have to space the tires out 3 to 4" off the hubs to clear the fenders or cut the fenders off entirely which would greatly reduce the structural integrity of the tubs. On the flip side. Spacing the tires that far out could be done... but only with very narrow tires otherwise you'd put a ton of leverage on the short axles and likely break something fast. Maybe in snow and marsh you could get away with it, but any kind of hard use on rocks would break something.Originally posted by john swenson View Posti wonder if anyone has put really large ballon paddle tires on a coot. i wonder how that would perform if it was done ? johnboy va.
Castro Nice find! I'd surely pick one of those up in a heart beat for that price state side. The only limitation I see is the open diffs, but that could be easily fixed with a spool or locker.
