After reading several times to go through buffalo bearing for new bearings on my max ii, I started wondering how good is the chain they sell? Would make it really convenient to order all from one source but I'm also on a budget and if there's a cheaper source for quality chain I'm all for it, well for any parts. That leaves more money for other modifications and repairs, I'm trying to knock the major stuff out so I can ride and do the little stuff as I go. Any suggestions for quality chain for a good price?
Buffalo bearing
Thank you I'll be calling them in the next couple days. I'd imagine I can get my axle bushings too.Originally posted by john swenson View Postdw, i've bought lot's of bearings from them and also their o-ring chain and sprockets. all have been quality parts. not sure what brand the chain was ( was not china) but it's lasted thru alot of abuse. they know these machines so it's worth a call to them. good luck....... johnboy va.
I finally found your half track video, your max is a beast!!DanW
Hope this helps
2000 MX II Prts list
HI All
After several hrs of researching parts for my overhaul I have decided to use these parts and venders for my overhaul, I hope this will help others.
Chains, MFG Supply
Nomenclature
5200-ring-102-w1-520 O-ring chain 102 pins $159.12
520O-CL-W1 - 520 O-Ring Motorcycle Chain Connecting Link 5 $19.95
530O-RING - 530 O-Ring ATV Chain. 182 pin 182 pin $89.18
530O-CL-W1 - 530 O-RIng Motorcycle Chain Connecting Lin $19.95
Total $288.20
Buffalo Bearing, 714-874-1720
Nomenclature Qty Price Total
HC 207-20 R3 outer bearing 12 $17.44 $209.28
SA206-20 Inner bearing 6 $13.07 $78.42
PF207 outer bearing plate 6 sets $12.96 $77.76
Total $365.46
Carts Plus 888-861-2640
High Rev Kit 1 $90.00 $90.00
tiny tach 1 $35 $35
Total $124.00
Mudd- Ox 1-888-898-2746
70117 center splined sprocket 2 $154.32 $308.64
70140 front/rear sprocket 4 $60.39 $241.56
70545 L/H jackshaft 1 $97.87 $97.87
70550 R/H jackshaft 1 $83.21 $83.21
Total $731.28
Nice, great bit of info. Thank you.Originally posted by garretttpe View PostHope this helps
HI All
Chains, MFG Supply
Nomenclature
Total $288.20
Total $365.46
tiny tach 1 $35 $35
Total $124.00
Total $731.28DanW
I ordered my chains and triple sealed bearings and bushings for now. The price seemed more than fair 230 something shipped to south central Pennsylvania. I should've ordered 12 bearings and built some cages but my electric service won't handle my welder, yet. Also my chair is broke so I'm kind of stuck stock piling parts until I can get it fixed. Greg was a pleasure to talk with and very helpful and so was the lady that answered the phone. As long as everything I ordered is good quality il definitely be a repeat customer.Last edited by Dw89xj; 07-25-2017, 08:48 PM.DanW
