So I have a 70's Swamp Fox and it doesn't want to go over about 7 mph. The belt looks alittle loose so couldn't that be the issue or does it sound like a bad torque converter? Any help would be greatly appreciated! Forward and reverse work fine so I am hoping the trans is fine.
speed problem
Finding a new belt size isn’t impossible you may be in luck and one could exist close to what you need.
https://www.mcmaster.com/#v-belts/=1a93g0w just some examples there are many more (you’ll pay more for odd sizes)
What I did was take out the old belt, measure its length with a cloth tape. Than make a belt from cardboard layered to the same thickness and cut to the same width. I wrapped that around the clutches as if it was the real belt and snipped it to the correct length. The only problem was the cardboard method will usually give a too perfect fit and you want some slack so add an inch or so to be safe. Then compare to the original belt the two shouldn’t be a huge amount off.
From your hard to see picture it looks like you have a 1-7/16 belt on there now, the driven would have had either 1-3/16 or 1-1/4 stock, also the driven probably has a green spring in from the four stroke. The drive is also probably set up for a larger diameter driven.
Sounds like lots of issues going on there, personally I'd 4 stroke it so you can use it. However now you probably can't tell if there is a band issue going on either ( hopefully it's fine like you hope).
Is the engine spinning up over 5000 rpms and not going fast or lugging and 7 is all it will pull at low rpm's?
Post a better pic for people to chime in on, your belt deflection should be 1"-1-1/2".sigpic
