So I was thinking that I might buy some old 8x8 or 6x6 and then rebuild it into a tracked vehicle. I was thinking about using tracks from a BV-206 (620 mm wide) and replacing the front wheel with a BV-206 drivewheel.
I'll extend the axles so the tracks will fit and perhaps try to fit a bv-206 suspension instead of the original wheels depending if it would be possible or not.
The vehicle would of course have to become higher, but that would allow it to drive over steeper slopes and holes, right? A problem i'm thinking about is that the engine weight might make it dip forward if I replace the front wheels, any solution for this or just put a weight on the back?
It would get much wider but the track pressure would be extremely low so it should have extremely good capabilities in snow and mud. I also think it would mostly likely not be able to float anymore, but if it does the tracks should be able to propel it forward as the BV-206 is amphibious and uses the tracks to propel forward.
What do you guys think about this? A good idea?
If I ever would build my own tracked vehicle from scratch I would use the German double diff steering using an electrical engine and a steering wheel. I guess I'll keep this post updated on my ideas to rebuild but before I make any progress I need to buy a cheap 6x6 or 8x8 broken or not.
