I'm still going ahead with my jet drive fit to my Max 4,
After searching thru this forum, previous jet drive and some propellor fit outs
Don't seem to have yielded large improvements in water speed.
My Max 4 achieving 7 kph in saltwater (GPS speed) with 26 inch Terras pretty
Good it seems.
One theory I have is the Max floats higher in saltwater, eg in freshwater I'm not far off
The top deck , haven't done a good GPS run in fresh yet,
In saltwater definitely floating higher, like 3-4 inches below the top deck.
In simple terms, salt means less drag because less of the wheels are in the water .
Another water drive alternative would be an Arneson surface drive.
Considering 6x6 is likely to go into weeds, swamps, water with grass etc
The Arneson (also called the weed chopper) would excel where props and jet drives
Block up.
Also as a surface drive doesn't have to be totally submerged , it would mount higher on
The rear of the vehicle.
I looked some web links and small surface drives are available.
Have a look and see what you think.
Mind you I wouldn't be walking behind an AATV with one........
Regards
OZ
Good it seems.
Block up.
Regards
OZ
