The above paragraph is the story, skip to the bar line if you don’t like wasting your time reading.
Okay so I’ve been throwing around the idea of selling my 94 max ii, but this thing has taught me a lot. From the rebuild, to the breakdowns, and the struggle to make her a reliable machine again and so on, but I digress..
I added new headlights with new wiring, (fault in old wiring)
Added a winch, (half-wired it)
Heated throttle cable, (really half-wired in)
And would like to add a cig lighter power outlet (for funzies)
Also added a dual battery in the back right for more power running a winch for a snow plow that never happened. (And want to replace with a regular single car battery, then make old battery spot a tool compartment)
llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllllLllllllllllllllllllllllll
I want to rewire the entire machine. Pull everything, and start over with an organized, professional, and clean approach. What I want to know is, do I need a relay? Do I NOT need one? What size fuses? Where should I have a fuse, where should I not? Good place to get a little customizable fuse box and so on. I want to learn how to do this but have no idea where to start do it right.
