help clutch belt
  • help clutch belt
    I have a max iv and I cant seem to get my clutch belt on. Any ideas? I had to take it off to put a chain on that fell off right below it.
    Not sure what engine you’ve got. Some harder than others. Take the drive clutch off loop the belt on then put clutch back on. You may even have to take shims out from under the engine if ther is any. Hope this helps.
      Hey Jim. I found it is just as easy to take the nuts off the engine stand on the opposite side of where the clutch is. I then just loosened the nuts on the side of the engine stand under the clutch. This allowed me to tilt the engine just enough to easily get the belt on. Hope that it works for you.
      "I'm NOT stuck, I'm just temporarily stopped"
