I have a Hustler that I continue to have axle and sprocket problems with. It seems the V-Twin is too much for the old sprockets with the wallowed-out holes. It was suggested that I switch to keyed or splined axles. What machine uses these that I can get a set? I do have one keyed axle already. Will I need anything other than the axles and sprockets? Bearings, flanges, ?? Thanks!
Splined axle conversion
You can try and contact whipper on the other page, he has done 3 or so Hustlers I know of using splined axles. Probably won't be cheap but should be right, no complaints from the members running them now.sigpic
I've got a set of Whippers in my Hustler and can't hurt them. I'm throwing big HP at it, turning heavy/ aggressive tires, and I've been told I drive my machines pretty hard. You will go from 1 3/16 to 1 1/4 axles, so you will need at minimum outer bearings. might as well replace inners while you are that far inOriginally posted by ARGOJIM View PostYou can try and contact whipper on the other page, he has done 3 or so Hustlers I know of using splined axles. Probably won't be cheap but should be right, no complaints from the members running them now.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
I myself can say if you my friend haven’t bent any of those axles I’d say they’re just about indestructable!!! Lol.Originally posted by racerone3 View PostI've got a set of Whippers in my Hustler and can't hurt them. I'm throwing big HP at it, turning heavy/ aggressive tires, and I've been told I drive my machines pretty hard. You will go from 1 3/16 to 1 1/4 axles, so you will need at minimum outer bearings. might as well replace inners while you are that far in
We have a set of Whipper's axles on the BFD and turn some pretty serious tires as well. I've never bent one but Bud has (but that's Bud).Stuck in the seventies- not in the swamp.
Where do the keyed axles come from? The one that was on my Hustler when I got it is the only axle of my 6 that I've not had a problem with. Are they a factory part?
Is is possible to have my axles (3 are only 6 months old) and sprockets cut for keyways at a machine shop? As much as I love the work that Whipper has put into that springer 6x6, it seems a bit more than I'm looking to do. I have already replaced the inner and outer bearings along with those 3 axles, and considering that I've been trying to sell this thing, the smallest can of worms is the best right now.
I run 1 inch keyed axles in an Attex with taper lock bushings and sprockets with a stainless key and have not destroyed one yet except my 1st run I didn’t have the key all the thru the bushing! Got in a hurry and missed that but other than that they’ve been great so far and I’m fairly rough on my machine.
Good luck with it
Dave
You could have the axels cut for keyway, cut off the sprocket tube with the hole in it and weld on a 1 3/16” sprocket hub to the sprocket. Replace hub set screws with hex bolts and crank them down tight with locktight to prevent striping the set screw. Put sleeve spacers on each side of the sprocket between the bearings to stop sprocket from moving side to side if it did get loose. I use this set up on my 100 hp springer. Hubs are cheap on surpluscenter.com. Try not to cut the keyway near the axel bolt hole to make a weak spot. Hope this helps.
