Hello out there!
I have a 2003 Argo Conquest equipped with a 20 hp Kawasaki liquid cooled engine model FD620D-JS12. I am experiencing an issue whereby the engine will start without issue and will idle perfectly until it reaches operating temperature. Once at operating temperature and load is applied (attempt to move) the engine shuts down. It will not start again without closing the choke. Once the choke is opened the engine shuts down again. If I leave the choke closed it shuts down due to flooding of gas I suspect. I changed out the gas in the tank with fresh gas and treated it with gas line antifreeze. This didn't seem to help at all. The air filter looks to be a bit dirty but not that bad. I checked the compression in each of the two cylinders and am satisfied that the compression is good. Both cylinders showed between 160 and 170 psi on the gauge. The carburetor most likely could use a cleaning. Is there anyone out there who has experienced something similar to this? When the engine shuts down it's like it loses spark or gas. I'm just confused as to why the engine runs perfectly until it reaches operating temperature!!! Any help will be greatly appreciated.
Thanks,
Colin
Thanks,
Colin
