Hey guy's and gal's;
Got just over 200 hours on my 2007 MaxIV and find that it's just about time for chain replacement. I am out of adjustment travel and previous posts suggest that this is the time to call in an order for new chain. Suggestions welcome.
Is 200 hours an early death for 530 o-ring chains? I have lubed and cleaned their entire life, but have operated in dusty and sandy environments.
Thanks,
Rutledge Fuller
BTW: I did order new chains and idler sprockets at over $700 from Richard. I might postpone installation for a few months, but once the chains slack again they are done.
Thanks,
Rutledge Fuller
R.I.P sage rogers 4 11 09 .
I've been considering this very thing for a Racer Attex I'm working on. The belts will be pricy, and getting pullies machined up (I plan on fitting to Whipper's Splined Axles) will be also. Once it's disassembled it should be easy to put axles in most of the way, slip belt over the axles, and once all belts/axles are on work one end at a time onto pullies. With Anti-seize and regular maintenance, it should be easy to remove and re-install axles to do belts. Dust/Dirt and mud should not wreck the belts, although they WILL shorten their life, I suspect the effect will be much less so than on chain, belt can give so sand doesn't grind in there, just a trip aroup pully and falls out. A stone or pebble, on the other hand, would punch right through, so inspections would be critical. Efficiency is where I am not sure, I think belt is more efficient, but I'm not sure on that, and I'm also not sure on weight. The pullies will be heavier than sprokets, belt of comperable strength should be lighter, so ???
