my neighbors friend aquired a older argo 8x8 ( maybe mid to late 80's ) and said there is a fan on it to cool the brake pads and rotors . is that original or modification , etc ? or something else ? thanks johnboy va
argo brakes fan
it's a great machine. Dead simple to work on. One thing I would suggest is to have some good 5/16 bolts around 2 1/4 to2 1/2 " long kicking around to replace the axle pins if they break. Bolts are way stronger. You just need to flatten the head off on one side and drill through the other end for a cotter pin or something to stop it falling out of the axle. Alot easier to smack them out then the roll pins too when it comes time to change a bearing
As mentioned the brake fan was standard on some and optional on other 8 wheelers since the 80s.sigpic
