IM A HDPE TEC. AND ON COILED PIPING THEY RUN IT THRU ROLLERS THAT GENERATE SOME HEAT TO STRECH IT SO IT LAYS FLAT .IF YOU ARE GOING TO HEAT IT LAY SOMETHING HEAVY ON IT BEFORE IT COOLS SO IT LOOSES ITS MEMORY..IT IS SOMETHING THAT YOU WILL JEST HAVE TO PLAY WITH.. THE SHEET STUFF IS EASIER TO WORK WITH. A LOT OF THE BIGGER PLUMBING HOUSES CAN GET IT IF THEY CARRY THE PIPING..SOME OF THEM CAN EVEN GET IT WELDED TO YOUR SPEC. WITH A EXTRUDER GUN , WHICH IS LIKE A MIG WELDER ,THAT USES HDPE WIRE... I HOPE THIS HELPS
E-K-C
Jest Wanted To Let You Know also ---Do not Use A Open Flame On Hdpe It Is A Petroleum Product And Will Burn Quickly...:
E-K-CJest Wanted To Let You Know also ---Do not Use A Open Flame On Hdpe It Is A Petroleum Product And Will Burn Quickly...:
