So I guess this is how 6x6ing goes, my bazoo head gasket arrived today, so I dropped everything to get it done. Headgasket done I went to fire it up and in ran real bad, I changed the points and condenser so I thought maybe there was something up there but I was convinced it was fueling as it ran perfect on idle. So some mixture adjusting later and it just quit on me. Stripping the engine down I found the woodrough key broken. Yay I thought and put it back together and the same thing with lots of backfireing. So a quick trip to the manual revealed my timong mark is no where near the place it is in the manual. I guesed where it was and retimed it to that mark and whew, it runs great, I should say in the mean time I had also discovered the choke spindle was broken and the choke was free to do what it wanted.
Well I now had full throttle and a hatered for the thing, I keep threatening to change the engine, that I decided it was time for a maiden dunk in the pond. Well it floats and goes.........backward, I guess I need to swap the wheels over to the other side, would this also make it better in the snow?
Well as I was going backwards and the other end of the pond was much steeper, half way out I started taking on water and loosing grip, there is a vent on the front of the bazoo and it decided it would like to be lower than the level of the water, nothing left to do but head back in with enough power to turn it as it really does not go forwards at all. So back on dry land I decided to pull the plugs only to find out one of them was stuck in with filler and id fell off in my hand so I need to find something better before heading back put into water. On the way back to the house the exhaust gasket went, it's been blowing for a while but I never have gotten around to it. So I pull up and have a look at tightening the exhaust only to find that one of the studs has snapped and I need to try and drill it out (if I can get a drill in the gap!) so my day is over, the bazoo runs like a dream, it needs the choke, exhaust and the drain plugs.
But I learned the whole engine covers do not need to be removed to pull the flywheel as is just fits through the hole. And I need to really think about working out what way to put the tires on.
At least I didn't need the rope I was packing just in case
