So after the replacement of my worn out idler shaft sprocket, I really need to keep up my chain maintenance, and im wondering what lube is recommended, also one of my problems is that, in the winter I get alot of snow in the machine which then melts and freezes up around the chains, I have to cross a lake to get to my cottage therefore I don't want to keep the the drain plugs out, and in the summer, I don't use it that often it sits outside covered, but the rain water seems to seep through the stiching in the cover, and when remove my floorboards, again i have my chains sitting in water, and rust starting to form, I use a really sticky industrial chain lube, but I find if i go for a ride, and have any amount of water in the bottom, they end up getting washed.
any suggestions?
any suggestions?
). It's common in industrial applications, and works very well. Most of the Argo owners that I know use it. I use a paintbrush to apply it, it will not sling off the chains, and it will not wash off either. With the paintbrush, it's easy to apply without contaminating the brakes, and can be applied to the front right axle chain, just in front of the battery.
