i got a small dent in my tub.. almost a hole.. what is the best way to fill that hole up? is there something i can do to use as a body filler type. the reason i want to fill it is if i am going over sticks now the sticks would find that dent and have a place to hold as the push threw my tub. the dent is about a inch round.
fixing a tub
Cole wrote a great article in the "How-to" section of the site about body repair. You might want to check that out.
One fix...
I had a guy nice enough to back into mine and knock the winch mount thru the bottom.. To change out the lower tub is over $5,000... What the dealer wound up doing was sandwiching the hole with two pieces of material he had (from an old tub) siliconed it with black, and bolted the two pieces together.. I think he used 10 bolts and the patch was roughly 12" x 8". I think it is alot stronger than the orginal and right at the lower winch mount...
