I have owned 3 Hustlers and ridden in many other 6x6s 8x8s and numerous tracked vehicles. I always enjoyed my Hustlers but had nagging problems which I finally remedied with my last Hustler. I would like other opinions on what people have found.
All of my Hustlers had problems keeping the tension correct on the chains. I have adjusted chains until I thought I would go crazy. Finally on my last machine, 16 hp Kohler, I had a friend of mine design and install spring tensioners on all chains. They worked perfect!! The last 2 years I owned the machine I adjusted the chains at the start of hunting season and never touched them again. Now 10 years later I can even remember how they worked all I know is that they did!!
The second problem I had was periodic breaking of the pin holding the sprockets in place. I solved that with grade 8 bolts long enough so the solid section was through the sprocket not the threads.
After the modifications to the 16 hp machine I felt it was nearly perfect. Many times I carried 4 people,gear and 1 or 2 deer several miles through river bottomland with no problem.
A couple of years ago I found out that Hustler made a large tired version. I would have loved to have one of those or at least seen and driven one. The extra ground clearance would have been helpful because I was battling roads used by 4x4 jeeps and trucks. There was no 3 wheelers or 4 wheelers when this all started!
Another need mod I had was adapter to run duals on the rear of the machine. I used these when it got really bad.
Well I better shut up, I look forward to talking about lots of vehicles.
Mike
Mike
