does anyone lube their chains, and if they lube them what do you use to lube them?
chain care
I use cable and chain lube from napa. be sure to keep your chains clean such as no dirt or debris in the tube if you take yours swimming and water gets in dirt will too. I lube mine about every tank or so of gas i run through. The biggest thing is proper chain tension is maintained to ensure long life. for the chains there is no such thing as too much lube but it will cover the inside of the tub.The feat of sinking a max is a badge of honor.
