Hi Everyone,
I am in the process of restoring a Hustler 950. I uploaded about 50 pictures into the Hustler 6x6 gallery today. Anyway, I have it stripped down to just the bottom tub with the frame, chains, and the six axles. Four of the axles have wheels/tires on them. There is a lot of dirt, grease. oil, and some sand in the bottom and it needs a super cleaning job. My questions is: Can I roll it outside, tilt it on its side and pressure wash it? I would rather not have to remove the axles and frame down to the tub only to clean it. Can the two wheels on the axle support the frame while its on its side? I don't want to damage/bend anything. Once I get it cleaned, I can start more of the restoration process. Needless to say, I will have a million more questions. Thanks and let me know.
Al
Al
I also scrubbed the rusty areas with a wire brush and then applied some de-rusting spray. I am going to re-apply some more rust remover then paint the metal. Now that it is clean, I agree with both of you and I am thinking about going ahead and removing the frame from the tub. I am going to put it up on milk crates so I can inspect the axles more closely before I make the decision. One thing I did notice is that on at least one of the axles there is a little bit of play. For example, when I turn a wheel it will turn about an inch before it contacts the axle. I noticed a few of the bolts that go through the axle joining the inner and outer rods are loose. Is this normal? Should they be tight? Thanks,
But really, it will be easy once you get started and you will see everything you need to remove.
I basically removed the sprocket bolt then removed the three bolts from the flange plate. I was then able to slide the axle out. I noticed the sprocket hole is slightly elongated (do you agree, see picture). Does the sprocket bolt look the right size? Also, the three bolts basically go through the frame (from the inside) through a rubber seal and plate that is pressed against the tub and then through the outer plate with the bearing sandwiched in the middle then some lock washers/bolts to secure it. Does that sound correct? Do I need to mark the sprockets so they go back on correctly or is it obvious once they are all removed? Sorry for all the questions but I want to get it right.
