When I first purchased my Frontier 650 from the dealer I noticed soon after that the paint on the sheet metal under the plastic floor pan was pealing. It looked like the paint never really adhered to the metal.
Last year I decided to fix that and coat the sheet metal at the front and rear with bedliner in a can (Duplicolor). I thought I had done a good prep job, wire brush and degreaser but the bedliner kept bubling and wouldn't stick
. I had noticed that the metal had a different appearance in some area when I removed the original paint. Finally was able to do an ok jop with touch up. After one hunting season, the bedliner all flaked up at the same areas.
This year I figured I would do a better job. Wire brushed the whole thing off (that stuff is pretty good in the ares where it actually stuck to the metal!), cleaned it off with paint thinner and Simple Green degreaser. Used a primer. I figured I was in the clear, this morning I started spraying the liner, same thing! In some area the liner is cringling and bubling.
Any idea what is going on? Did something get spilled on the frame at the factory?
. I had noticed that the metal had a different appearance in some area when I removed the original paint. Finally was able to do an ok jop with touch up. After one hunting season, the bedliner all flaked up at the same areas.This year I figured I would do a better job. Wire brushed the whole thing off (that stuff is pretty good in the ares where it actually stuck to the metal!), cleaned it off with paint thinner and Simple Green degreaser. Used a primer. I figured I was in the clear, this morning I started spraying the liner, same thing! In some area the liner is cringling and bubling.
