winch
  • winch
    Love this sight!!
    Well moose hunting season is over here in Alaska , I hunt with a couple of other argo-nuts & we had some discussion of winches . I have a RULE 4200 winch that came with my machine (very happy with it), brother in law has a super winch 3000( Not so happy ), brother has a warn 2000 ( well its ok ) Barney just bought a 3500 Ramsey, winched twice & the hex shaft stripped out, (Not happy at all )
    What winch do you use and the pound rating?
    What IS the best winch out there?
    I think the RULE winch with the planetary drive is awsome, but they are out of business & no longer make them. I have used warn, ramsey & some other off brand little winch (2000 lb) over the past 20 years & think the RULE has been the best one I have used to date.
    Would appriciate any feed back from anyone but am curious what winch Rock Doctor uses?
    Not trying to d
    If you have a marginal winch, get one of these to double the pulling power. Even if you have plenty of winch, it's still usefull for a non straightline pull. I have a 10 year old 2000 warn, and with the block it'll get me out of anything. I have taken the winch apart and serviced it, that always helps.
    Search results for: 'snatch block'
      Thanks Roger.
      I / we have been using the "snatch blocks" for years & yes they are worth their wieght in gold when needed.
      As with the argo itself, we service our winches periodically & hence find problems BEFORE going out into the mud & mountains. Good advice & thanks.
        I think RD is up in the 4000#+ zone. Of course he moves cabins and bridges with his.
        On the flip side, I know a guy with a MaxII, who uses a lightweight low # winch, skips breakfast, and runs a 1/2 tank of gas just to keep vehicle weight down, so his chances of coming out of a mudhole are better.
        Will be good to hear feedback about the good and bad of current winches.
          I have a 3000# Promark winch on my 4 wheeler. Mine is the XTR version with a synthetic rope, I will never go back to a steel line. It has performed well and seems well made. I believe it is the same as Viper, etc. but not positive. I also use a snatch block on almost all pulls. So far it has been a good purchase and it comes with a lifetime warranty.
            Thanks arp35, I'll check out the Promark, don't think I've heard of that one before. I'm doing research for my buddy to replace his new Ramsey with somthing better built.
            Of course, if the winch is there, we will use it........ To its limits!!!
            With an 8X8 argo we don't have to skip ANY meals, on the flip side, when an 8X8 gets stuck, it is nice & handy to have an adequate winch (that works) to get her out.
            I agree, & thats the beauty of this sight, getting feedback from people who run pretty much the same machines in different enviroments.
            Last edited by Mike; 09-29-2010, 05:06 PM. Reason: merged two consecutive posts. You can reply to everyone in one post by using the multi quote button.
              I run a warn works 4700lb, it is good so far. The only complaint I have is the solenoid on mine got damaged and I had to buy a reversing solenoid from cole hersee, I then mounted in the engine compartment to protect it from damage. I use mine for winching and plowing, but better make sure your charging system and battery are in good order, it uses a bit of power.
                I carry an extra 50 ft of cable and an adaptor I made up that I bolt on to one of the front axles if I have to. Although I don't run the best winch (Viper) it has done me well. The reason for the extra cable and adaptor is that I can use the engine and trans to assist my winch. And the extra cable takes the beating/twisting instead of my winch cable. Only had to use it once, but in conjunction with a 2:1 pull setup, pulls like on ice.
                It's all just nuts and bolts.
                  I'm also a fan of the RULE4200. If I could have my way it would have a 100ft spool, like the 3000lb. I would also like to see a faster line speed, but I guess you can't have your cake and eat it too.
                  I've tried a few of the cheeper brands, Gold Winch, Superwinch, Motomaster, ect. At the end of the day, I think you get what you pay for.
                  I have a couple 2000lb Warn Winches on my quads, and have had pretty good luck with them, Just don't use them to "Tie Down" your quad, and they should be fine.
                    Thanks garbie, that is a consideration I over looked. The hp rating of the electric motor.
                      Thnaks Jeff, going back to our construction days,,,,,,,, using wheel power/adapter to assist in reeling it in with a second line, good thought!
                        I was sad to hear the Rule is longer made & found a sight that still sells parts (Rule Winch Parts Supply & Repair - In Stock!) when I bought my 1999 Conquest it came with a Rule 4200 & when I went to use it for the first time, there was some sparking going on when I put the hook to the "D" ring, disassembled & found the brush holder broke, cleaned it all up & made an Alaska backyard repair till I could get new parts. Well 1 & 1/2 years later it is still working GREAT & just located this above metioned sight, contacted them & they have a new motor in stock with brake at $260.00 with a $140.00 core. Little spendy but this winch pulled an overloaded argo with trailer up hill after I spun out, my 50 foot cable was about 10 foot short, but with that spare rope that everyone wants to know why you are caring that all the time for, finally came in handy!
                        By the way RD, I bought 2 new clutches this past spring, after running them this summer & after moose hunting, I modified the driven (tranny clutch) like you suggested, using the # 1 hole for the spring & this made an unbelievable difference in the performance! Turns on a dime in high gear, engine brakes down hill like you would not believe, in low gear! Made a new machine out it! I'll wait till the drive clutch starts to show some signs of weekening or next spring before adding a shim. I added a shim to the old drive clutch spring after cleaning it up & adding dry graphite, put it on my brother inlaws machine & now he won't give it back! sniffle sniffle, we are gone rebuild his old for a spare & now I have 2 more machines my buddies want me to "TUNE UP" their clutches. Easy fix really, so just wanted to THANK YOU for your input & videos. Much appriciated!
                          ..............................my 50 foot cable was about 10 foot short,............................(Posted by moose-a-boo)
                          Murhpys law of winching; If you have 50 feet of cable on your winch, you will get stuck 51 feet from a good anchor point. If you increase that cable to 100 feet, you will get stuck 101 feet from a good anchor point. Therefore, it is a good idea to carry the extra (I keep 50 ft with hooks on ends) cable. And I carry a cable pinch so I can hook anywhere along the length of the cable when rigging if I have to.
                            The joys of being outdoors, its the adventure!
                              Originally posted by moos-a-boo View Post
                              By the way RD, I bought 2 new clutches this past spring, after running them this summer & after moose hunting, I modified the driven (tranny clutch) like you suggested, using the # 1 hole for the spring & this made an unbelievable difference in the performance! Turns on a dime in high gear, engine brakes down hill like you would not believe, in low gear! Made a new machine out it! I'll wait till the drive clutch starts to show some signs of weekening or next spring before adding a shim. I added a shim to the old driven clutch spring after cleaning it up & adding dry graphite, put it on my brother inlaws machine & now he won't give it back! sniffle sniffle, we are gone rebuild his old for a spare & now I have 2 more machines my buddies want me to "TUNE UP" their clutches. Easy fix really, so just wanted to THANK YOU for your input & videos. Much appriciated!
                              Glad I could be of service
