talked to super winch there x 1 andx2 winches are made in america . the new terr winches are made in china i kill winches right reg .the promark and mile marker are china made . i have taken both apart both are parts inchangeable they look the same . i know some of u have had good luck with some of them . they doint last and are not as good of quialty . so jest a heads up on what i have found out there will be a super winch x 2, 3000 lbs winch on our maxs soon . robbie X2 & X2F 3,000 lbs X-Series Utility - Superwinch
winches made in american
R.I.P sage rogers 4 11 09 .
you can't fix stuped !!!!! raceone 3 .)Tags: None
I too have put winches "head to head" and I have found that if you want a high quality winch 1. you cant get it for $199.00 2. Warn makes pretty much the toughest small winches on the planet. I have pull tested them side by side and the Warn wins everytime.09' ARGO Avenger 750 EFI
With near every option Argo makes
and a few they don't
thanks going with a super winch x2 i know thay have been on lewis and mcCoys argos . over 5 years with no problems robbie1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
