8x8 or 6x6 climbing onto ice while in deep water
  • 8x8 or 6x6 climbing onto ice while in deep water
    dose any one have video of climbing back onto good ice while out in deep water like icefishing I have an early 70's argo 6x6 that I'm going to rebuild but not what I going to use for ice fishing to short to brittle to much work to modify rather find an 8x8 that needs major rebuild I have a 25 hp kohler or a 27 hp water cooled kawsaki for one but would like to see video out on the ice I fish saginaw bay mi. air boat is ideal but not as much fun in warm weather
    in most situations you will need to get out of the Argo and walk ten feet drill a hole in the ice to anchor a wench and pull your self onto the ice
    Kevin Hough
    TREBMASTER
    (____>
    .OOO
      I also live in Michigan and love to Ice fish,Where abouts do you live?
      Kevin Hough
      TREBMASTER
      (____>
      .OOO
        I've fallen through ice a couple times (River and Lake), and both time it was a PITA to get the Argo back up. Used a similar technique to what trebmaster mentioned.
        My advise......Try not to fall through
        I also have a 27HP Kawi (Brand New in the box), I plan to drop that in one of my Conquests this winter.
          Do you run tracks or tires? and if tires did you ever think about a couple of atv chains on the front tires and possibly middle tires as well. I saw that a couple of ppl on here use them so I tried it out on my pond this past weekend with just chains on the front tires (I only have 1 set right now) and I purposely broke through and the chains made a lot of difference they pulled me right back onto the good ice. The ice was only about 3-4 inches thick but those chains grabbed it like I have a machine with studded tracks, I plan on buying a second set of chains for the middle axles because with 21 inch tires I have plenty of clearance to run them in the middle as well.
            I also forgot to mention I have a 1978 MAXII machine.
              Originally posted by golpher76 View Post
              Do you run tracks or tires? .
              If I want to take the Argo out in the winter, I pretty much need to have my tracks on. Too much snow to run without. Good idea with the chains, I've heard similar things about them for plowing snow, works good, as long as you don't get too deep in the fluffy white stuff.
