The area I ride in was logged some years ago. Add to that 2 major hurricanes and put it together in a creek bottom crisscrossed with sloughs and prone to flooding and it's just a certainty that you're gonna get to deal with submerged logs.
One of my favorite riding holes is one that has at least 4 logs and a stump or something (Not sure what it is but I'm not sticking my hands down in there to find out either
) that gives a real challenge. The first log you have to go over, points nearly straight at the entry into the hole, you have to be careful not to straddle it, but you HAVE to get over it to get to the next one. Then you have #2 about a 6X6 length ahead, which is about 18" above the surface to the right, angling down to about 12" below the surface on the left. It will slide you over against #3 which lays on top of #2, and is against the bank, which is walled with BRIARS. IF you get on top of #3 you have to finesse your machine slightly around to the right and HURL yourself forward to get over #4 and out over the... ?stump? log? All while floating in at least 4' of water.
It is, as I said , my favorite spot because if I miss ANY one of the maneuvers then I get the biggest challenge of all, getting back out to try again! This is a hole that I could drive around, but where's the fun in that! I thought about getting a set of chains, but if I did, the hole would be easier and therefore less fun! So what set-up do you guys like for submerged logs, swimmers, mudders, or a mix?
I'm not asking what tire is best, I just want to know what setup YOU like in a situation such as this.
) that gives a real challenge. The first log you have to go over, points nearly straight at the entry into the hole, you have to be careful not to straddle it, but you HAVE to get over it to get to the next one. Then you have #2 about a 6X6 length ahead, which is about 18" above the surface to the right, angling down to about 12" below the surface on the left. It will slide you over against #3 which lays on top of #2, and is against the bank, which is walled with BRIARS. IF you get on top of #3 you have to finesse your machine slightly around to the right and HURL yourself forward to get over #4 and out over the... ?stump? log? All while floating in at least 4' of water.It is, as I said , my favorite spot because if I miss ANY one of the maneuvers then I get the biggest challenge of all, getting back out to try again! This is a hole that I could drive around, but where's the fun in that! I thought about getting a set of chains, but if I did, the hole would be easier and therefore less fun! So what set-up do you guys like for submerged logs, swimmers, mudders, or a mix?
