I got a hub and sprocket from tractor supply to replace a rear sprocket on my machine. I had the set screw drilled out and for a sheer bolt and got the axle welded on. I went was messing around with it trying to get it on a new axle I was making and realized that the hole in the sprocket hub was a little too small to slide over the axle. I was going to use my die grinder to grind it to size, but decided to call a machinist buddy of mine first. He informed me that using the old die grinder would egg out the hole no mater how careful you are. I was told to get a piece of emery cloth and attach it to a drill bit. Then just stick the hillbilly tool in the hub and run the drill. He said it would conform to the original shape of the whole keeping the shape true. I took his advise. I grabbed a bit (5/16th I think), wrapped the end of emery cloth around it overlapping 1 full wrap, and put 2 small binder clips on it (one on top and one on bottom ends of the bit/cloth setup). Of course I took the finger press things off the binder clips. Then stuck the bit in the drill, wrapped the cloth up tightly, and slid it through the hub. Wouldn't you know it worked perfectly. I just let it run in the hub for a few minutes at a time, and kept checking to see if it would slide over the axle till it worked.
He said this is what they did at work when something needed slightly bored out. Hope someone else finds his advice useful.
