I've got a nice little camel i've deciced to get elbows deep into and restore...,but the hull is cracked..got any repair sugestions that will not look like crap...thanks 6x6
What do you guys do to weld cracked and broked hulls and tops
I'm not sure what the Camel bodies are made of. they are on my "must have list" but I haven't run up on one yet. I think they are ABS bodies. you can test by rubbing it with some acetone. if it gets a little soft with acetone, then it's ABS. Your options are plastic welding, or "ABS goo". A search for either term here on the site will get you lots of results for either. If the body is POLY, then welding is your only option. Fiberglass is repaired with more fiberglass. Good luck and post up some pics of the machineA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
