old argo lower tub repair-What's good to use for repairing them?
  • old argo lower tub repair-What's good to use for repairing them?
    Can anyone tell me what's a good sealent for the plastic tubs on the old 70's argo's?
    The best sealant for a poly tub is....Well, poly. http://www.6x6world.com/forums/conte...dy-repair.html
      I found a crack on the lower body. An old rusted nut was wedged between the frame & the tub causing the tub to split from pressure. I bought a plastic welder, the type has a flat iron on the end. It was difficult to get on the inside of the tub but i heated mostly the outside & used the plastic welding rod that comes in the welding kit & fused it & covered it. It seems OK.. I'm removing all the axle bearing covers & re sealing them. My 70 has the 3 bolt style flanges. Hopefully next time on the water It is dry inside. I did install a bilge pump up front & have another 1 coming for the middle.
