ABS Plastic reapair
  • #31
    Was yours an ABS body? They don't seem to weld as well as the poly bodies.
    http://www.amp-phibian.blogspot.com/
    • #32
      Gave it another try, this time I let the mixture sit in a sealed container for a while to consolidate a bit before I applied it. I also put it on thinner and tried not to work it too much, the next day it was a lot harder than the other time. I think thin layers are the trick. I also did a brush over with acetone to keep the surface wet longer, don't know if it helped or not but I guess it can't hurt.
      • #33
        Hey JRP3, Glad its working better for you. I tried the welding before and it didnt work very well like the abs goop.
        That abs goop is abs and after the acetone evaps there is no non like material left. Attex actually sold the same idea in a body repair kit and I have also hear attex and amphicat gooped up the seams of the upper and lower tubs before they stapled them.
        • #34
          If I can find some MEK I'm going to try that instead of acetone, I've heard it might work better than acetone and I think that's what Oatey uses in their black ABS glue. So far I've only found a gallon container of it, much more than I'll ever need. I might try some of the Oatey stuff as well since I have a few cracks in the black engine cover.
          • #35
            I used PLF 400 subfloor adhesive and fiberglass tape on my '96 Max IV. It worked great, and I plowed at -20 with it all winter, and no cracks. Damage was in wheel well.
            I ride a brown '96 Max 4 (skid plate, roll cage, 26" Rawhides, 20hp, custom winch and tow plates) with a 2K front winch and a 4K come-along for back up. I pack 20'tow-strap, 2 chains and 2 hooks,a jeep jack, and a big block of PT wood. Also an axe and chainsaw. And mechanic tools. I have a tote with a tarp and bungees. Spare parts. Two rifles. Hey, arent I supposed to be able to have three passengers?
            • #36
              That fiberglass mesh tape like for drywall? That and the "goop"?
              Cave Trolls Rule!
              • #37
                Did a full lower body re-skin with fiberglass cloth and epoxy resin, description here: http://www.6x6world.com/forums/gener...tml#post106898
                • #38
                  Car bumper repair kits work well, I have used them on quad plastics and Argo bodies. It uses a chemical reaction to bond the repair patch to the plastic.
                  • #39
                    Weld-On #4707 Pint (1707) Plastic Adhesive Glue
                    This what i repaired the Crush with. It can actually be used to fill hole like a body filler. Make sure your parts are where you want them when you glue up, because once dried it is over. Can be sanded and painted.
