Addendum- Please accept my apology, I get running my mind and mouth and writing to cover all the important stuff that I usually forget something and I omitted an important piece you mentioned.
“New style” and “heavy duty”- First, those claims mean whatever they mean and are wholly worthless in most cases because they are advertising terms and not engineering functions. In bearings specifically I can answer that and I consider it truly “need to know” because in many cases “new and improved” and “heavy duty” can be the single fastest way to get the WORST possible solution and create more problems than they solve.
A bearing is locked into several constants that cannot be changed. ( normally the ID,OD and width because it still has to fit in whatever it has to fit without substantial re machining)
A bearing only does one thing- it rolls. The only 2 other considerations ( which affect it) are does it roll fast or roll under a lateral load. Go back to the simple ( and not fully complete because there are hundreds of potential considerations) specification list above. In most cases “heavy duty” simply means they reduced the inner/outer race and installed beefier rolling media. That may or may not help you ( and can work against you) depending on the specific reason YOUR bearing in YOUR application failed.
It can also mean other things like different heat/cold treatment, finer finish for vibration reduction or specialty lubrication, has a different race design to accommodate some kind of load and so forth.
See, these “new improvements” are rarely anything new or improved. ( or heavy duty because the APPLICATION, not the bearing, defines the “duty” and whether its “heavy” or “light” and since bearings are broad based and fit many radically different machines and because they are fitted by dimension any given manufacturers bearing such as a 6205 may or may not meet all the other criteria you need for “your” application depending on the rest of those numbers)
You get these “improvements’ ( for lack of a better term) because all end users work with component manufacturers and give them all kinds of failure data, customer complaints and conduct testing ( again against that list earlier for bearings) so they conduct or revise their design FMECA (failure mode effect and criticality analysis)and find out the failure mode for that application ( greater load capability, increased heat tolerances, greater misalignment capability and so forth) and as a result they go back and address whatever is in the baseline design and “augment” it.
The specifics are really infinite so just be careful when you are retrofitting anything or considering stuff like “new and improved, “heavy duty” and whatnot because UNLESS you specifically why YOUR bearing is failing and then you know EXACTLY what property(s) were changed from the baseline design- you may wind up in a worse predicament with anything “new and improved” or “heavy duty” because they have strengthened a different parameter ( and as a result weakened the one that is causing your specific failure) so despite all good intentions you can make your particular situation worse.
Just friendly advice from one who deals with this every day.
