I have recently bought a hustler 880 with a 400ccw motor in it. With winter coming up I'm trying to figure out how to make a plow for it. Anybody have any ideas?
Hustler 880 Plow
I'd suggest doing what Recreatives does on their Max ATVs and make two steel plates that bolt onto your front and middle bearing flanges. Fab up a pair of plates for each side and weld on a pin on each for the plow frame to mount and raise and lower on. Then use a winch to bring the plow assembly up and down."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I'll throw my 2 cents in. The 880 can have some frame issues as its not as robust as the later hustle models. The other issue is the 2 stroke engine. high revving - low torque isn't all that great for what you are trying to accomplish. i'd just have fun with the machine and not dump a tone of $ at a plow set up that will leave you wanting."Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
Use it for winter fun, and then while you're doing that, keep your eye out for a good deal on a 4 stroke machine to use as a workhorse. You can never have too many 6 wheelers!
