Hi all,
Well,
I started tearing into the new Hustler today, and, have a couple of questions.
I hope this is the right catagory.
I got no books or anything with this rig, so, am flying by the seat of my pants, as it were.....
I'm wondering how tight the drive chains should be?
I'm guessing it's fairly important they be equal?
They seem kind of loose, some draging on frame parts......
The sprockets seem pretty good, teeth mostly have a little "square" left on the ends...the chain seems good, too.
Also:
Are the chain tensioners, except for the main power from the trans, which are both sprockets, supposed to by just nylon rollers? They all look the same, so, I'm guessing they are, but, one is pretty shot, so, I need to find a new one, I just want to make sure if I'm replacing something, it is the correct thing in the first place. I'd rather replace them all now with the correct part if they're wrong.......
The axles look good, bearings look to have new grease, and, don't seem to wobble.
The frame doesn't seem to have any big breaks, although, it looks to have been fixed and modified over the years a few times.......
It has a hand brake, but, not hooked to anything. Is there a provision for a "parking brake" that I just can't see?
It has an automotive battery with tray, that look like they were added. Good job though, and, with the extra alternator, seems a good set up.
I put the new drive belt that came with it on.....I'm sure there's an easier way than how I did it........hahaha can someone tell me the correct procedure?
I'll quit for now, in hopes you all don't get to frustrated with my "newbie" questions........
I'm wondering if there is a good repair manual available?
Thanks,
Well,
Also:
Thanks,
