Hello working on the hustler I just got and wondered why it was binding when turning , found the middle wheel on one Side , I can move the wheel like its pulled out where it goes into the body , so I have to buy a whole new axle for $115 ?
Hustler 954 help
Ok , I'm learning ,,,lol ,, man I thought I snapped the axle ,lol , looks like I need to replace all the stuff around the axles , bearings flanges, the others look all crappy , this thing has been sitting in a barn since 1980 , or wait till they break ?? The chains look sort of pitted also , I'm going to have to go buy another 6x6 so I have something to ride , why I tear this thing down ,, lol ,, you guys got me really thinking about the bad lands !!
Avoid Route 6x6. You're going to end up paying way, way too much for parts there. Many of those parts are of inferior quality too. There are PLENTY of other places to get parts. You can have a machine shop make you up axels, transmission and other parts such as throttle cables, choke cables, etc are available from Recreatives Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 and bearings can be purchased through Buffalo Bearing. (716) 874-1720. Spend a little time shopping and reading here on the site and you'll be able to do a high quality rebuild on a budget.Originally posted by Gratt View PostAlso is the route 6x6 place the only place to get parts ? For my hustler ."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Hustler help
Me again , ok I got the axle that was flopping around all loose ,outer bearing is gone , but I am stuck on the very last flang on the axle , has a set screw in it , I got the set screw loose and out but the axle still won't pull out , do they rust on ? Man I restore garden tractors but that is a job , what you guys think should I just replace them all ?
They sure do rust on. Soak it daily with penetrating oil and when you reassemble it use lots of the silver anti seize stuff. If it won't come off, cut it with a die grinder and just order a new one. It's the 3 bolt flange that mounts to the upper body that you're referring to, right?"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
No them came off but this is a ring about 1/8 big in dia. Then the axle , has a alen screw , I though you loosen the screw and the axle would slide right off , it maybe part of the bushing , it's like a locking coller for very end of the axle,
$45 is about 3 times too much for bearings. They should be closer to $15 or so. The inners are 52mm OD, not sure of the ID, 1" I believe, and they fit in a stamped two piece flange. Make sure you get "R3" (meaning triple lip seal) outer bearings, 62mm OD, 1-3/16" ID and they also fit in stamped two piece flanges. Call the guys at Buffalo Bearing and tell them you're with 6X6World and they'll take good care of you. (716) 874-1720."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
