25 inch tires on a hustler?
  • 25 inch tires on a hustler?
    Anyone know if I can fit a set of 25 inch aquatorques on my hustler 900hk?
    It looks like I can with about a half inch clearance on the tub. Has anyone done this?
    Steven Untiet
    25 rawhide3 fit. Aquatorques ride terrible and don't swim. There are better tires available for the money
    Acta non verba
      Any suggestions? I am not too worried about swimming, I rarely if ever swim, beside just to do it because. I have been researching and thinking about tires forever and thought i decided on the aquatorques, It was either that or 24 inch factory argo tires. They came down to about the same cost, actually the aqua's were a little cheaper?????
      Steven Untiet
        asx vampires
        1996 MAX IV ,KUBOTA DIESEL
        MAX II 30HP Bandolero
          Vampire would require different rims. I can't seem to find any that have the five bolt hole pattern.
          Steven Untiet
            I would choose the Argo tires over the Aquatorques anyday,no ??'s asked.
            Joe.
              Really?
              Maybe I will go with the Argo tires. It's so confusing as to which tire to choose. I thought I had decided on the aquatorques now after your posts I'm not sure. I thought those would be the ideal tire, big and meaty.
              Steven Untiet
                Big an meaty for sure, tried them on my springer an they road like you were driving on the rumble strips on the edge of the highway. I'd go with the Argo's
                Acta non verba
                  Originally posted by countrycummins99 View Post
                  asx vampires
                  The Vampire ASX tires are GREAT, but they only come in a 26" size and won't fit the shorter Hustler 900, 945, 950.......only the 980.
                  If you get Aquatorques you'll need 9" rims. If you get the 24" Argo tires you can use the stock Hustler 8" rims.
                    Matts new Vendetta tires may fit?
                    Acta non verba
                      The Vendetta's are running about 26.75" Matt was not sure if the tire mfgr could make a special set at 26 or under????
