forward-reverse lever
  • forward-reverse lever
    Is there a how to on adjusting the spring rods. I have tried the search but to no avail. We have lost reverse playing with the adjustments.
    Your shift mechanism attaches to the 2 diamond shifters located next to the output sprockets. These will be all the way back when in reverse and all the way forward when in forward. If your mechanism does this, pull them and check the little pins. The 1/4" round dowel pins move the internal shift collar that determines forward and reverse. These often break off or get flat spots making shifting hard or impossible.
      Thanks. Just got it. Seller said he was fine tunning the adjustment. Kind of showed how to. But have made it worse not knowing what to do.
