I just got my first 6x6, its a Hustler in pretty good shape except it has no motor. What would be my best route to go to get it going?? Thanks.
Just got a Hustler..
Congratulations on picking up your Hustler. I think the best route for you is to get a motor.
Decide what you want to repower it with and drop it in. What model Hustler did you get and what kind of motor was originally in it? Do you have the CVTs for both the transmission and the motor?
Make makes some good points and asks a great question. Another good question is what so you want it to do. Do you want a trail machine that climbs like a beast and can pull a good load on a trailer or are you more into going fast? With a 4-stroke, you will be lucky if you can go 25mph, but it will do about 18mph through almost anything and pull like no body's business. If you have the clutches, you may want to just go with something similar to what was there. There is a good chance it was a 2-stroke originally, and you may want to keep it that way. They are much faster than a 4-stroke as well as much noisier. They also don't have the low end torque. Your options are only limited by your budget and ability to find deals on the required parts. I have built both 2 and 4 stroke machines. My 2-stroker is a race only machine and is a blast, but doesn't see near the use my big 4-stroker does. It's got a plow for the winter and takes the whole family into the woods in the spring, summer, and fall.l like to buy stuff and no I don't do payments!
CVT,only the trans,I don't know what the original motor was, its a four seater, I don't know what the model is. I'm thinking of just getting a wrecked snowmobile for the motor and clutch but I don't know what size(cc's) would be the best..Or should i buy a 4 stroke Briggs or Honda? I have a lot of learning to do so be patient with me if my questions seem goofy..
If you can post a couple of pictures model info may follow, engine as Drew wrote is as to a preference of a go fast machine or a go all day machine. Fabrication work will probably be required down either route.sigpic
So a fiberglass 880HK probably had a Kohler 440 2 stroke ( unless I'm dyslexic on the letters and it was a Hirth). You'll need a green or red spring for the driven clutch, a 4 stroke of your choice and a 4 stroke drive clutch to start, either a 780 style or a Comet 94c, using a commonly accessible belt is a plus, plus a bunch of misc. like wiring etc..
What color(s) is it? Does it have a jet pump ( nozzle sticking out of lower rear)? There are more than a few members on here with the 880's, check out the Hustler gallery.sigpic
The very first Hustler 880 came with a single cylinder K-309 2 stroke Kohler. They also had an Apex gearbox with a jackshaft/clutchpack configuration for the drivetrain. Then they switched to a CCW 340cc two stroke, two cylinder and a T-20 transmission. I believe these were the only 2 engines available in the 880 fiberglass body Hustlers. Then they went to the the HDPE plastic bodies and 2 cylinder 2 stroke Kohler engines."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
