Finally got one of the troublesome rear axle inner bearings removed. Helps if I use metal cutting discs in my angle grinder instead of masonry cutting discs...
Anyway, I got the bearing out, and subsequently ruined it by hammering on the wrong part.
That being said, after examining this bearing, I am fairly sure that 1) it's not the right bearing, and 2, it can't be flipped in the flange to make it work correctly.
Here's some pics of the bearing in question. Here are the pics of the bearing:
Flange:
Insert:
Grease ports on insert:
The "retaining collar" is actually built in to this bearing.
Flange:
Insert:
