I just picked one of these things up and am I glad I found this site. I'm into vintage snowmobiles so this will be a fun new hobby. I need to know where to look for a data plate and or how to ID the year. This thing looks almost complete but is missing the steering sticks so I'll need help finding them. It has a L/C Chapparall engine. 340 or 440 not sure yet. Twin 38mm Mics, sitting in the "soup" as I type. It will need all 6 tires. I also got a Brand New canvas cover it looks like it's never been on the unit. 40 hours on the meter! Look forward to chating about this with you guys. Kevin.
I just got a Hustler and I've got questions.
Originally posted by mountaintoyparts View PostI just picked one of these things up and am I glad I found this site. I'm into vintage snowmobiles so this will be a fun new hobby. I need to know where to look for a data plate and or how to ID the year. This thing looks almost complete but is missing the steering sticks so I'll need help finding them. It has a L/C Chapparall engine. 340 or 440 not sure yet. Twin 38mm Mics, sitting in the "soup" as I type. It will need all 6 tires. I also got a Brand New canvas cover it looks like it's never been on the unit. 40 hours on the meter! Look forward to chating about this with you guys. Kevin.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )if it don't float with out you getting wet . don't bring it !
R.I.P sage rogers 4 11 09 .
Hi Kevin, welcome to the site and congratulations on acquiring a 6x6 Hustler! Try http://www.tiresunlimited.com for the common 22" rawhide III tires or look around the site and see what others are running if you want a tire specifically for mud or just for water, etc.
As for the identification, I will have to let one of the Hustler experts chime in on that. A lot of them are at the Ledges ride this weekend but I'm sure someone will chime in when they get back.
Kevin ,
Good luck with your Hustler project , and welcome to the amphibious forumJP swift is the man to see if you have a Hustler.
Heres the really sweet part about this new toy. It came with a bag something I just opened this morning and this is what it was. A practicly brand new cover. Not only the zip and snap on 3 piece with windows but then there was this complete cover to go over all of that. Almost NOS condition.
Now back to the other pics. See where the controls are missing the sticks and whatever they attach to? I need those parts!!! Can anyone help? I also need a throttle cable. (but can make one if I have to) I need a brake cable, she's froze. I also need jetting and clutching specs for 8000feet. It has a Comet Duster primary clutch. Still not sure of engine size. My snowmobile books are not helping figure that one out and I can't see any markings yet. It had 360 mains and 40 pilots so when I got it running it was stumbling all over itself. I dropped the mains down to 250 and she screams (on the trailer). I'm guessing I should pull the chains off and service or replace them. They are tight and a little rusty. A good shopvac and a bath is soon to follow. Still would like to know what model this is to?Last edited by mountaintoyparts; 07-27-2008, 11:54 AM.
Very cool on the top....had not seen one like that before!
Several thoughts:
1) Throttle cable-If it was me I would give Recreatives Industries (Max) a call and buy a Max style throttle lever and Max IV throttle cable. This is what I have on my Hustler, and the handle is aluminum instead of plastic.
2) It looks like you are just missing the laterals on your controls. Richard Clarke would have some, or you could fabricate some, I can take some pics if you need them.
3) Since you are buying a used machine, I would highly recommend changing all bearings and chain. This will increase reliability a lot, plus you will be able to re-seal the flanges in a proper manner to get your Hustler water-tight. There is an excellent article on this site that shows the proper axle flange sealing steps when changing your bearings. Depending on what size tires you wish to use, you may want to go with a different inner bearing, I used some two bolt flange bearings that moved my axles out about 1", giving me more clearance for wider tires. Buffalo Bearing is a good source for bearings...triple sealed outer bearings for about 17 bucks.Hammers should have warning labels.
No, I have not seen any foot controls or dash controls...don't think you'd want them either, as you tend to bounce around a lot sometimes....easier to hang on to the sticks I guess. Plus, if they were floor mounted you would have to remove them every time you removed the floor pan for cleaning. Another trick I figured out to keep your throttle cable from getting water in it, is that if it is raining or you are trailering your Hustler, get one of those bottle beer Koozie's that zips up, this will fit nicely over your throttle handle and keep it dry and warm!
I will take some pics of my laterals in the next few days.
BTW, here is a thread that has Buffalo Bearings phone # and the part #'s
And here is a pic of the inner wheel bearings I used, I got them because they were stronger than stock, and then realized later that they had the added benefit of moving the tires out by an inch or so.
hustler rebuild1 001 pictures from outdoors photos on webshots
Don't forget there is a great article about wheel bearing changes on a Max on this site, the sealing procedures are first class and will work great on the Hustler. In addition to silicone you will need some 3M strip caulk, otherwise known as dum-dum. A lot of auto parts stores do not carry this anymore. I found mine at FinishMasters, which is a automotive paint supply house.
BTW, were you aware your Hustler has an I.V. bag on it??Hammers should have warning labels.
Hey Mountain,
Sorry for the delay....work's been keeping me busy. I uploaded some shots of the laterals, the first is here.
Hustler 001 pictures from outdoors photos on webshots
I took about five pics. Hope this helps.Hammers should have warning labels.
Thanks for the pics boncrshr! I think if I can't find some for sale, I can fab them from the pics. Got all the chains off now, gonna replace them. Added a choke cable to augment the primer set up. Looking for a brake cable now. Need to get it off the tires to check out the bearings. Should a guy replace the bearings arbitrairily or if they spin freely leave them alone? Thanks again!
You're welcome...
If it was me, I would replace the bearings. You are already going through the trouble of replacing all of the chains, so this would be even more peace of mind. Also, it gives you the opportunity to properly re-seal the axle flanges. Just my .02.....but for 120 bucks and some elbow grease it is a pretty big bang for the buck.Hammers should have warning labels.
