I just bought a Hustler for $275. It's missing a lot, but I like a challenge. What kind of motors work with these beasts? I'm guessing anything from 14 - 22 horsepower? Mine has no engine, but it does have a good T20 and clutch.
A New Hustler Owner
That sounds like a pretty good deal, depending on what kind of shape the Hustler's in. Different models came with different engines: everything from a 15 Kohler single to a 440 Kohler 2-stroke twin. With all the room in the engine bay, there's not a lot of limits to your power choices.Stuck in the seventies- not in the swamp.
Certainly it could work, but I suggest you keep looking and find something with more horses. If you go with the 16, make sure it is in good condition so you can realize all 16 of those horses. Also, although obvious but make sure its a horizontal shaft engine and the crank is 1 in. diameter x roughly 3 inches long with a 1/4 inch keyway. That way your clutch options are better.
You may have to modify the engine mount and if so, pay very close attention to belt alignment and tension.
So here's what I've got....
I do have a few parts that aren't pictured. Engine cover, seat, etc.
Is there a serial number I could look for, or a model number somewhere?
Also, is there anything available that I could look at to help fabricate missing parts?
For instance, the top of the transmission has 2 "arms" not hooked up. I believe they might be for forward and reverse. I have no clue what's missing. If I had something to look at, it would be much easier.
Anyway, what do you think?Resized1.jpgResized2.jpgResized3.jpgResized4.jpgResized5.jpg
You got a great deal! So the picture I pasted above is my machine and you can see the shift linkage framework. Your framework has been cut off for some reasons, so you will have to rebuild it. Those two arms coming off the transmission are the forward, neutral, reverse controls. I can get better pictures or measurements for you. Although my machine is a little different model, I believe all the frame and internal components are basically the same.
