Hi guys, Has anyone installed a heated throttle from a max4 on a hustler? I have a 25 Kohler Command in mine and it froze up on me last winter. Had to cover it with a blanket and put a ceramic heater in it for 45 minutes or so. Thanks for any help you can give me. Later Mike
Will a max 4 throttle cable fit -hustler 980 Bigfoot
mike d ,
The throttle assembly on the Hustler Bigfoot that I recently bought was broken , so the previous owner gave me a new aluminum , throttle assembly , for a Max IV , and it fit perfectly on my Hustler Bigfoot. I would assume that a heated throttle assembly for a Max , would also work on your Hustler as well ?Last edited by mudbug3; 10-28-2008, 04:13 PM.
the heater part of it is easy to hook up, it is just a switched power and a ground. i use mine all the time in the winter on my max 2. also use a cable luber to lube it it helps force most of the moisture out of the cable so its less prone to freezethey dont call me mad because im angry!!!!! im just a little crazy thats all!!!!
in jays pocket lolOriginally posted by mike d View PostI called R.I. and talked with Jay. He didn't think I'd need the heated cable so I got the regular one. Also got a muffler for my max 2 and seat belts. Where does the money go??? Later Mike
