No reverse im guessing linkage thing any thoughts and yes i am pulling back lol thanks in ADVANCE
Hustler wont go in reverse
Wereonem,
What's the history on this machine? Did reverse just quit working one day? When you are going forward are you able to apply the brakes by pulling back on the laterals?
Check the following:
1) band adjustment
2) linkage is actually pushing the diamond shifter fully into the reverse position. If you have any question, disconnect the linkage at the diamond and shift it by hand.
3) pull the diamond shifter and check the pin. Pins can be worn to the point that it won't engage reverse. Pins can also be broken completely off, but then you wouldn't have forward either.
